Time Before: 0.00399 seconds
Time After: 0.00473 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00484 seconds
Time After: 0.00536 seconds
Time Before: 0.00561 seconds
Time After: 0.00577 seconds
Time Before: 0.00643 seconds
Time After: 0.00863 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00583 seconds
Time After: 0.01258 seconds
Time Taken: 0.00675 seconds
Time Before: 0.01563 seconds
Time After: 0.01584 seconds
Time Before: 0.01904 seconds
Time After: 0.02041 seconds
Time Taken: 0.00136 seconds
Time Before: 0.01480 seconds
Time After: 0.02064 seconds
Time Taken: 0.00584 seconds
Time Before: 0.02918 seconds
Time After: 0.02934 seconds
Time Before: 0.03191 seconds
Time After: 0.03321 seconds
End call of global.php: 0.035526990890503
Time Before: 0.03723 seconds
Time After: 0.03745 seconds
Time Before: 0.04022 seconds
Time After: 0.04172 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1789041771, location = '/forums/private.php?do=newpm&explain=1&u=49062', badlocation = 1
Time Before: 0.06075 seconds
Time After: 0.06255 seconds
Time Taken: 0.00181 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.059424161911011 seconds with 9 queries, spending 0.0094454288482666 doing MySQL queries and 0.049978733062744 doing PHP things.
