Time Before: 0.00677 seconds
Time After: 0.00918 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00928 seconds
Time After: 0.00973 seconds
Time Before: 0.01000 seconds
Time After: 0.01011 seconds
Time Before: 0.01100 seconds
Time After: 0.01319 seconds
Time Taken: 0.00219 seconds
Time Before: 0.01018 seconds
Time After: 0.01668 seconds
Time Taken: 0.00651 seconds
Time Before: 0.01991 seconds
Time After: 0.02009 seconds
Time Before: 0.02160 seconds
Time After: 0.02277 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01924 seconds
Time After: 0.02298 seconds
Time Taken: 0.00374 seconds
Memory After: 2,261.836 KB
Time Before: 0.03197 seconds
Time After: 0.03208 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.04000 seconds
Time After: 0.04124 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.043586015701294
Time Before: 0.04665 seconds
Time After: 0.04680 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.04935 seconds
Time After: 0.05079 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789139587, location = '/forums/private.php?do=newpm&explain=1&u=49131'
Time Before: 0.06798 seconds
Time After: 0.06882 seconds
Time Taken: 0.00083 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.066896915435791 seconds with 9 queries, spending 0.0078854560852051 doing MySQL queries and 0.059011459350586 doing PHP things.
