Time Before: 0.00788 seconds
Time After: 0.01126 seconds
Time Taken: 0.00338 seconds
Time Before: 0.01135 seconds
Time After: 0.01204 seconds
Time Taken: 0.00069 seconds
Time Before: 0.01232 seconds
Time After: 0.01251 seconds
Time Before: 0.01347 seconds
Time After: 0.01658 seconds
Time Taken: 0.00312 seconds
Time Before: 0.01258 seconds
Time After: 0.02154 seconds
Time Taken: 0.00896 seconds
Time Before: 0.02593 seconds
Time After: 0.02642 seconds
Time Before: 0.02891 seconds
Time After: 0.03012 seconds
Time Before: 0.02517 seconds
Time After: 0.03037 seconds
Time Taken: 0.00520 seconds
Time Before: 0.04953 seconds
Time After: 0.04974 seconds
Time Before: 0.05510 seconds
Time After: 0.05632 seconds
Time Before: 0.06124 seconds
Time After: 0.06141 seconds
Time Before: 0.06390 seconds
Time After: 0.06532 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=49279' WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.08298 seconds
Time After: 0.08347 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
