Time Before: 0.01071 seconds
Time After: 0.01527 seconds
Time Taken: 0.00455 seconds
Time Before: 0.01535 seconds
Time After: 0.01579 seconds
Time Before: 0.01605 seconds
Time After: 0.01621 seconds
Time Before: 0.01702 seconds
Time After: 0.01911 seconds
Time Taken: 0.00209 seconds
Time Before: 0.01626 seconds
Time After: 0.02404 seconds
Time Taken: 0.00778 seconds
Time Before: 0.03084 seconds
Time After: 0.03154 seconds
Time Taken: 0.00070 seconds
Time Before: 0.03469 seconds
Time After: 0.03591 seconds
Time Before: 0.03001 seconds
Time After: 0.03618 seconds
Time Taken: 0.00616 seconds
Time Before: 0.05628 seconds
Time After: 0.05644 seconds
Time Before: 0.06984 seconds
Time After: 0.07106 seconds
Time Before: 0.07877 seconds
Time After: 0.07892 seconds
Time Before: 0.08142 seconds
Time After: 0.08292 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=49286' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.09981 seconds
Time After: 0.10643 seconds
Time Taken: 0.00662 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
