Time Before: 0.00149 seconds
Time After: 0.00193 seconds
Time Before: 0.00201 seconds
Time After: 0.00248 seconds
Time Before: 0.00274 seconds
Time After: 0.00289 seconds
Time Before: 0.00361 seconds
Time After: 0.00628 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00294 seconds
Time After: 0.01126 seconds
Time Taken: 0.00832 seconds
Time Before: 0.01350 seconds
Time After: 0.01375 seconds
Time Before: 0.01632 seconds
Time After: 0.01751 seconds
Time Before: 0.01273 seconds
Time After: 0.01778 seconds
Time Taken: 0.00504 seconds
Time Before: 0.02989 seconds
Time After: 0.03001 seconds
Time Before: 0.03322 seconds
Time After: 0.03455 seconds
Time Taken: 0.00133 seconds
Time Before: 0.04017 seconds
Time After: 0.04035 seconds
Time Before: 0.04322 seconds
Time After: 0.04503 seconds
Time Taken: 0.00181 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=49315', badlocation = 1 WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.06133 seconds
Time After: 0.06158 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
