Time Before: 0.02226 seconds
Time After: 0.03089 seconds
Time Taken: 0.00863 seconds
Time Before: 0.03099 seconds
Time After: 0.03137 seconds
Time Before: 0.03169 seconds
Time After: 0.03185 seconds
Time Before: 0.03273 seconds
Time After: 0.03468 seconds
Time Taken: 0.00195 seconds
Time Before: 0.03191 seconds
Time After: 0.04000 seconds
Time Taken: 0.00809 seconds
Time Before: 0.04999 seconds
Time After: 0.05037 seconds
Time Before: 0.05322 seconds
Time After: 0.05438 seconds
Time Taken: 0.00115 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04917 seconds
Time After: 0.05458 seconds
Time Taken: 0.00541 seconds
Memory After: 2,261.719 KB
Time Before: 0.08061 seconds
Time After: 0.08074 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.09748 seconds
Time After: 0.09950 seconds
Time Taken: 0.00202 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.10161209106445
Time Before: 0.11103 seconds
Time After: 0.11116 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.11386 seconds
Time After: 0.11528 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=49512', badlocation = 1
Time Before: 0.13294 seconds
Time After: 0.13320 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.13188600540161 seconds with 9 queries, spending 0.0079834461212158 doing MySQL queries and 0.1239025592804 doing PHP things.
