Time Before: 0.01766 seconds
Time After: 0.02547 seconds
Time Taken: 0.00781 seconds
Time Before: 0.02558 seconds
Time After: 0.02598 seconds
Time Before: 0.02622 seconds
Time After: 0.02641 seconds
Time Before: 0.02726 seconds
Time After: 0.02919 seconds
Time Taken: 0.00193 seconds
Time Before: 0.02648 seconds
Time After: 0.03490 seconds
Time Taken: 0.00841 seconds
Time Before: 0.04388 seconds
Time After: 0.04427 seconds
Time Before: 0.04665 seconds
Time After: 0.04783 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04322 seconds
Time After: 0.04802 seconds
Time Taken: 0.00480 seconds
Memory After: 2,261.836 KB
Time Before: 0.06978 seconds
Time After: 0.06997 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.09341 seconds
Time After: 0.09471 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.097281932830811
Time Before: 0.11017 seconds
Time After: 0.11035 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.11327 seconds
Time After: 0.11474 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789032820, location = '/forums/private.php?do=newpm&explain=1&u=49527', badlocation = 1
Time Before: 0.14240 seconds
Time After: 0.14281 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.14090085029602 seconds with 9 queries, spending 0.0076563358306885 doing MySQL queries and 0.13324451446533 doing PHP things.
