Time Before: 0.00144 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00249 seconds
Time Before: 0.00281 seconds
Time After: 0.00299 seconds
Time Before: 0.00392 seconds
Time After: 0.00669 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00307 seconds
Time After: 0.01012 seconds
Time Taken: 0.00705 seconds
Time Before: 0.01198 seconds
Time After: 0.01237 seconds
Time Before: 0.01474 seconds
Time After: 0.01598 seconds
Time Before: 0.01141 seconds
Time After: 0.01624 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02218 seconds
Time After: 0.02241 seconds
Time Before: 0.02440 seconds
Time After: 0.02568 seconds
Time Before: 0.03005 seconds
Time After: 0.03020 seconds
Time Before: 0.03324 seconds
Time After: 0.03476 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=49531', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.04760 seconds
Time After: 0.04799 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
