Time Before: 0.00166 seconds
Time After: 0.00211 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00218 seconds
Time After: 0.00266 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00284 seconds
Time After: 0.00297 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00364 seconds
Time After: 0.00596 seconds
Time Taken: 0.00233 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00302 seconds
Time After: 0.01063 seconds
Time Taken: 0.00762 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01244 seconds
Time After: 0.01288 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01531 seconds
Time After: 0.01653 seconds
Memory Before: 2,771.641 KB
Memory After: 2,771.500 KB
Time Before: 0.01184 seconds
Time After: 0.01670 seconds
Time Taken: 0.00486 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.531 KB
Time Before: 0.02163 seconds
Time After: 0.02179 seconds
Memory Before: 3,437.641 KB
Memory After: 3,438.156 KB
Time Before: 0.02404 seconds
Time After: 0.02542 seconds
Time Taken: 0.00138 seconds
Memory Before: 3,525.438 KB
Memory After: 3,526.031 KB
Time Before: 0.02954 seconds
Time After: 0.02968 seconds
Memory Before: 4,163.305 KB
Memory After: 4,163.734 KB
Time Before: 0.03203 seconds
Time After: 0.03350 seconds
Memory Before: 4,444.867 KB
Memory After: 4,446.555 KB
UPDATE session SET lastactivity = 1788870139, location = '/forums/private.php?do=newpm&explain=1&u=49636' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04797 seconds
Time After: 0.04823 seconds
Memory Before: 4,918.703 KB
Memory After: 4,918.930 KB
