Time Before: 0.00151 seconds
Time After: 0.00201 seconds
Time Before: 0.00208 seconds
Time After: 0.00258 seconds
Time Before: 0.00292 seconds
Time After: 0.00306 seconds
Time Before: 0.00390 seconds
Time After: 0.00661 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00314 seconds
Time After: 0.01000 seconds
Time Taken: 0.00686 seconds
Time Before: 0.01206 seconds
Time After: 0.01245 seconds
Time Before: 0.01510 seconds
Time After: 0.01635 seconds
Time Before: 0.01143 seconds
Time After: 0.01663 seconds
Time Taken: 0.00520 seconds
Time Before: 0.02411 seconds
Time After: 0.02426 seconds
Time Before: 0.02685 seconds
Time After: 0.02804 seconds
End call of global.php: 0.029750108718872
Time Before: 0.03111 seconds
Time After: 0.03130 seconds
Time Before: 0.03457 seconds
Time After: 0.03602 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=49684'
Time Before: 0.04929 seconds
Time After: 0.04958 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
Page generated in 0.048357009887695 seconds with 9 queries, spending 0.0082771778106689 doing MySQL queries and 0.040079832077026 doing PHP things.
