Time Before: 0.02236 seconds
Time After: 0.02865 seconds
Time Taken: 0.00629 seconds
Memory Before: 532.305 KB
Memory After: 557.422 KB
Time Before: 0.02872 seconds
Time After: 0.02922 seconds
Memory Before: 557.359 KB
Memory After: 558.367 KB
Time Before: 0.02954 seconds
Time After: 0.02968 seconds
Memory Before: 558.922 KB
Memory After: 559.445 KB
Time Before: 0.03041 seconds
Time After: 0.03231 seconds
Time Taken: 0.00190 seconds
Memory Before: 562.047 KB
Memory After: 562.969 KB
Time Before: 0.02975 seconds
Time After: 0.03722 seconds
Time Taken: 0.00747 seconds
Memory Before: 558.695 KB
Memory After: 1,639.742 KB
Memory Used: 1,081.047 KB
Time Before: 0.04630 seconds
Time After: 0.04667 seconds
Memory Before: 2,134.648 KB
Memory After: 2,135.266 KB
Time Before: 0.04908 seconds
Time After: 0.05030 seconds
Memory Before: 2,146.711 KB
Memory After: 2,146.570 KB
Time Before: 0.04551 seconds
Time After: 0.05054 seconds
Time Taken: 0.00503 seconds
Memory Before: 2,126.828 KB
Memory After: 2,259.922 KB
Memory Used: 133.094 KB
Time Before: 0.08568 seconds
Time After: 0.08583 seconds
Memory Before: 2,813.445 KB
Memory After: 2,813.961 KB
Time Before: 0.10386 seconds
Time After: 0.10510 seconds
Memory Before: 2,901.734 KB
Memory After: 2,902.328 KB
End call of global.php: 0.10715198516846
Time Before: 0.11542 seconds
Time After: 0.11557 seconds
Memory Before: 3,538.516 KB
Memory After: 3,538.945 KB
Time Before: 0.11814 seconds
Time After: 0.12074 seconds
Time Taken: 0.00260 seconds
Memory Before: 3,820.047 KB
Memory After: 3,821.734 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=49775', badlocation = 1
Time Before: 0.14074 seconds
Time After: 0.14103 seconds
Memory Before: 4,298.453 KB
Memory After: 4,298.680 KB
Page generated in 0.13940000534058 seconds with 9 queries, spending 0.0085656642913818 doing MySQL queries and 0.13083434104919 doing PHP things.
