Time Before: 0.02596 seconds
Time After: 0.03021 seconds
Time Taken: 0.00425 seconds
Time Before: 0.03031 seconds
Time After: 0.03072 seconds
Time Before: 0.03099 seconds
Time After: 0.03115 seconds
Time Before: 0.03198 seconds
Time After: 0.03424 seconds
Time Taken: 0.00226 seconds
Time Before: 0.03123 seconds
Time After: 0.03834 seconds
Time Taken: 0.00711 seconds
Time Before: 0.04560 seconds
Time After: 0.04604 seconds
Time Before: 0.04884 seconds
Time After: 0.05001 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04492 seconds
Time After: 0.05023 seconds
Time Taken: 0.00531 seconds
Time Before: 0.10288 seconds
Time After: 0.10306 seconds
Time Before: 0.12162 seconds
Time After: 0.12290 seconds
End call of global.php: 0.12489104270935
Time Before: 0.13283 seconds
Time After: 0.13315 seconds
Time Before: 0.13573 seconds
Time After: 0.13723 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=49836'
WHERE sessionhash = 'b1e9f976e3e130f3a0e1c3e688e54b68'
Time Before: 0.15398 seconds
Time After: 0.15423 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.1529529094696 seconds with 9 queries, spending 0.0079553127288818 doing MySQL queries and 0.14499759674072 doing PHP things.
