Time Before: 0.00153 seconds
Time After: 0.00199 seconds
Time Before: 0.00206 seconds
Time After: 0.00257 seconds
Time Before: 0.00279 seconds
Time After: 0.00293 seconds
Time Before: 0.00383 seconds
Time After: 0.00628 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00299 seconds
Time After: 0.01177 seconds
Time Taken: 0.00877 seconds
Time Before: 0.01426 seconds
Time After: 0.01472 seconds
Time Before: 0.01654 seconds
Time After: 0.01773 seconds
Time Before: 0.01347 seconds
Time After: 0.01800 seconds
Time Taken: 0.00453 seconds
Time Before: 0.02399 seconds
Time After: 0.02417 seconds
Time Before: 0.02663 seconds
Time After: 0.02788 seconds
End call of global.php: 0.029582023620605
Time Before: 0.03103 seconds
Time After: 0.03124 seconds
Time Before: 0.03361 seconds
Time After: 0.03504 seconds
SET lastactivity = 1785298092, location = '/forums/private.php?do=newpm&explain=1&u=49849', badlocation = 1
Time Before: 0.04821 seconds
Time After: 0.04867 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.046933889389038 seconds with 9 queries, spending 0.0083017349243164 doing MySQL queries and 0.038632154464722 doing PHP things.
