Time Before: 0.00140 seconds
Time After: 0.00188 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00195 seconds
Time After: 0.00239 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00265 seconds
Time After: 0.00278 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.00365 seconds
Time After: 0.00631 seconds
Time Taken: 0.00266 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00286 seconds
Time After: 0.00976 seconds
Time Taken: 0.00690 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.01147 seconds
Time After: 0.01191 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.01454 seconds
Time After: 0.01582 seconds
Memory Before: 2,148.203 KB
Memory After: 2,148.063 KB
Time Before: 0.01095 seconds
Time After: 0.01608 seconds
Time Taken: 0.00514 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.086 KB
Time Before: 0.02357 seconds
Time After: 0.02392 seconds
Memory Before: 2,814.633 KB
Memory After: 2,815.148 KB
Time Before: 0.02625 seconds
Time After: 0.02748 seconds
Memory Before: 2,902.938 KB
Memory After: 2,903.531 KB
End call of global.php: 0.029172897338867
Time Before: 0.03030 seconds
Time After: 0.03046 seconds
Memory Before: 3,539.703 KB
Memory After: 3,540.133 KB
Time Before: 0.03239 seconds
Time After: 0.03385 seconds
Memory Before: 3,821.234 KB
Memory After: 3,822.922 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=49930'
Time Before: 0.05000 seconds
Time After: 0.05024 seconds
Memory Before: 4,294.844 KB
Memory After: 4,295.086 KB
Page generated in 0.049076080322266 seconds with 9 queries, spending 0.0083727836608887 doing MySQL queries and 0.040703296661377 doing PHP things.
