Time Before: 0.00158 seconds
Time After: 0.00215 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00222 seconds
Time After: 0.00274 seconds
Time Before: 0.00293 seconds
Time After: 0.00304 seconds
Time Before: 0.00369 seconds
Time After: 0.00616 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00308 seconds
Time After: 0.01031 seconds
Time Taken: 0.00722 seconds
Time Before: 0.01220 seconds
Time After: 0.01272 seconds
Time Before: 0.01527 seconds
Time After: 0.01649 seconds
Time Before: 0.01155 seconds
Time After: 0.01666 seconds
Time Taken: 0.00511 seconds
Time Before: 0.02202 seconds
Time After: 0.02219 seconds
Time Before: 0.02581 seconds
Time After: 0.02702 seconds
End call of global.php: 0.029349088668823
Time Before: 0.03056 seconds
Time After: 0.03071 seconds
Time Before: 0.03269 seconds
Time After: 0.03411 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=49972', badlocation = 1
Time Before: 0.04670 seconds
Time After: 0.04705 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
Page generated in 0.045784950256348 seconds with 9 queries, spending 0.0081207752227783 doing MySQL queries and 0.037664175033569 doing PHP things.
