Time Before: 0.01435 seconds
Time After: 0.02037 seconds
Time Taken: 0.00601 seconds
Time Before: 0.02047 seconds
Time After: 0.02090 seconds
Time Before: 0.02113 seconds
Time After: 0.02127 seconds
Time Before: 0.02209 seconds
Time After: 0.02535 seconds
Time Taken: 0.00327 seconds
Time Before: 0.02133 seconds
Time After: 0.02982 seconds
Time Taken: 0.00850 seconds
Time Before: 0.03530 seconds
Time After: 0.03569 seconds
Time Before: 0.03827 seconds
Time After: 0.04042 seconds
Time Taken: 0.00215 seconds
Time Before: 0.03462 seconds
Time After: 0.04068 seconds
Time Taken: 0.00606 seconds
Time Before: 0.06594 seconds
Time After: 0.06615 seconds
Time Before: 0.07823 seconds
Time After: 0.07947 seconds
End call of global.php: 0.081513166427612
Time Before: 0.08595 seconds
Time After: 0.08621 seconds
Time Before: 0.08882 seconds
Time After: 0.09051 seconds
Time Taken: 0.00169 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=49981', badlocation = 1
WHERE sessionhash = '496e60a36d28cda8bc94210e8a89b07e'
Time Before: 0.10731 seconds
Time After: 0.10775 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.10626602172852 seconds with 9 queries, spending 0.010204315185547 doing MySQL queries and 0.096061706542969 doing PHP things.
