Time Before: 0.00173 seconds
Time After: 0.00224 seconds
Time Before: 0.00233 seconds
Time After: 0.00289 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00323 seconds
Time After: 0.00338 seconds
Time Before: 0.00425 seconds
Time After: 0.00692 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00349 seconds
Time After: 0.01047 seconds
Time Taken: 0.00698 seconds
Time Before: 0.01214 seconds
Time After: 0.01256 seconds
Time Before: 0.01406 seconds
Time After: 0.01529 seconds
Time Before: 0.01157 seconds
Time After: 0.01557 seconds
Time Taken: 0.00400 seconds
Time Before: 0.02060 seconds
Time After: 0.02075 seconds
Time Before: 0.02250 seconds
Time After: 0.02373 seconds
Time Before: 0.02732 seconds
Time After: 0.02748 seconds
Time Before: 0.02958 seconds
Time After: 0.03104 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=50012' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04401 seconds
Time After: 0.04427 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
