Time Before: 0.00206 seconds
Time After: 0.00274 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00281 seconds
Time After: 0.00337 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00370 seconds
Time After: 0.00390 seconds
Time Before: 0.00459 seconds
Time After: 0.00754 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00397 seconds
Time After: 0.01090 seconds
Time Taken: 0.00693 seconds
Time Before: 0.01304 seconds
Time After: 0.01344 seconds
Time Before: 0.01567 seconds
Time After: 0.01690 seconds
Time Before: 0.01245 seconds
Time After: 0.01707 seconds
Time Taken: 0.00462 seconds
Time Before: 0.02218 seconds
Time After: 0.02236 seconds
Time Before: 0.02427 seconds
Time After: 0.02557 seconds
Time Before: 0.02836 seconds
Time After: 0.02854 seconds
Time Before: 0.03052 seconds
Time After: 0.03199 seconds
UPDATE session SET lastactivity = 1777136663, location = '/forums/private.php?do=newpm&explain=1&u=50092' WHERE sessionhash = '7775e95b18bef93607bc556467059588'
Time Before: 0.04857 seconds
Time After: 0.04893 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
