Time Before: 0.01904 seconds
Time After: 0.02350 seconds
Time Taken: 0.00447 seconds
Time Before: 0.02358 seconds
Time After: 0.02413 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02435 seconds
Time After: 0.02451 seconds
Time Before: 0.02524 seconds
Time After: 0.02728 seconds
Time Taken: 0.00204 seconds
Time Before: 0.02457 seconds
Time After: 0.03205 seconds
Time Taken: 0.00747 seconds
Time Before: 0.03680 seconds
Time After: 0.03724 seconds
Time Before: 0.03977 seconds
Time After: 0.04108 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03605 seconds
Time After: 0.04133 seconds
Time Taken: 0.00529 seconds
Memory After: 2,261.836 KB
Time Before: 0.07078 seconds
Time After: 0.07102 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"31.75,\";s:9:\"lastcheck\";i:1789026141;}', 1)Time Before: 0.08450 seconds
Time After: 0.08488 seconds
Memory Before: 2,816.625 KB
Memory After: 2,816.875 KB
Memory Used: 0.250 KB
Time Before: 0.10050 seconds
Time After: 0.10184 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,903.930 KB
Memory After: 2,904.523 KB
Time Before: 0.11117 seconds
Time After: 0.11145 seconds
Memory Before: 3,540.734 KB
Memory After: 3,541.164 KB
Time Before: 0.11457 seconds
Time After: 0.11602 seconds
Memory Before: 3,822.313 KB
Memory After: 3,824.000 KB
UPDATE session SET lastactivity = 1789026141, location = '/forums/private.php?do=newpm&explain=1&u=50115' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.13507 seconds
Time After: 0.13544 seconds
Memory Before: 4,296.148 KB
Memory After: 4,296.375 KB
