Time Before: 0.00161 seconds
Time After: 0.00271 seconds
Time Taken: 0.00111 seconds
Time Before: 0.00278 seconds
Time After: 0.00367 seconds
Time Taken: 0.00089 seconds
Time Before: 0.00385 seconds
Time After: 0.00395 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00457 seconds
Time After: 0.00704 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00400 seconds
Time After: 0.01041 seconds
Time Taken: 0.00641 seconds
Time Before: 0.01244 seconds
Time After: 0.01286 seconds
Time Before: 0.01567 seconds
Time After: 0.01730 seconds
Time Taken: 0.00164 seconds
Time Before: 0.01178 seconds
Time After: 0.01748 seconds
Time Taken: 0.00571 seconds
Time Before: 0.02274 seconds
Time After: 0.02316 seconds
Time Before: 0.02604 seconds
Time After: 0.02778 seconds
Time Taken: 0.00174 seconds
Time Before: 0.03183 seconds
Time After: 0.03210 seconds
Time Before: 0.03410 seconds
Time After: 0.03555 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=50177' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04813 seconds
Time After: 0.04855 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
