Time Before: 0.00909 seconds
Time After: 0.01577 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01586 seconds
Time After: 0.01630 seconds
Time Before: 0.01658 seconds
Time After: 0.01671 seconds
Time Before: 0.01754 seconds
Time After: 0.02024 seconds
Time Taken: 0.00270 seconds
Time Before: 0.01677 seconds
Time After: 0.02420 seconds
Time Taken: 0.00744 seconds
Time Before: 0.03343 seconds
Time After: 0.03388 seconds
Time Before: 0.03546 seconds
Time After: 0.03667 seconds
Time Before: 0.03271 seconds
Time After: 0.03692 seconds
Time Taken: 0.00421 seconds
Time Before: 0.08357 seconds
Time After: 0.08393 seconds
Time Before: 0.10576 seconds
Time After: 0.10699 seconds
Time Before: 0.11883 seconds
Time After: 0.11899 seconds
Time Before: 0.12155 seconds
Time After: 0.12301 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=50315', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.14324 seconds
Time After: 0.14355 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
