Time Before: 0.01449 seconds
Time After: 0.01869 seconds
Time Taken: 0.00420 seconds
Time Before: 0.01877 seconds
Time After: 0.01916 seconds
Time Before: 0.01941 seconds
Time After: 0.01955 seconds
Time Before: 0.02037 seconds
Time After: 0.02268 seconds
Time Taken: 0.00230 seconds
Time Before: 0.01961 seconds
Time After: 0.02676 seconds
Time Taken: 0.00715 seconds
Time Before: 0.03445 seconds
Time After: 0.03489 seconds
Time Before: 0.03830 seconds
Time After: 0.03953 seconds
Time Before: 0.03371 seconds
Time After: 0.03979 seconds
Time Taken: 0.00608 seconds
Time Before: 0.07813 seconds
Time After: 0.07826 seconds
Time Before: 0.09682 seconds
Time After: 0.09807 seconds
End call of global.php: 0.10027194023132
Time Before: 0.10857 seconds
Time After: 0.10873 seconds
Time Before: 0.11155 seconds
Time After: 0.11302 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=50339', badlocation = 1
Time Before: 0.13368 seconds
Time After: 0.13397 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
Page generated in 0.13251805305481 seconds with 9 queries, spending 0.0078103542327881 doing MySQL queries and 0.12470769882202 doing PHP things.
