Time Before: 0.00204 seconds
Time After: 0.00272 seconds
Time Taken: 0.00068 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.00282 seconds
Time After: 0.00328 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.00350 seconds
Time After: 0.00366 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.00456 seconds
Time After: 0.00727 seconds
Time Taken: 0.00271 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.00374 seconds
Time After: 0.01303 seconds
Time Taken: 0.00929 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.01571 seconds
Time After: 0.01618 seconds
Time Before: 0.01964 seconds
Time After: 0.02099 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01497 seconds
Time After: 0.02124 seconds
Time Taken: 0.00628 seconds
Memory After: 2,261.703 KB
Time Before: 0.02703 seconds
Time After: 0.02717 seconds
Memory Before: 2,815.273 KB
Memory After: 2,815.789 KB
Time Before: 0.02968 seconds
Time After: 0.03099 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.033906936645508
Time Before: 0.03580 seconds
Time After: 0.03596 seconds
Memory Before: 3,540.375 KB
Memory After: 3,540.805 KB
Time Before: 0.03862 seconds
Time After: 0.04021 seconds
Time Taken: 0.00159 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=50397'
Time Before: 0.05914 seconds
Time After: 0.05938 seconds
Memory Before: 4,295.484 KB
Memory After: 4,295.727 KB
Page generated in 0.057822942733765 seconds with 9 queries, spending 0.0085999965667725 doing MySQL queries and 0.049222946166992 doing PHP things.
