Time Before: 0.00898 seconds
Time After: 0.01291 seconds
Time Taken: 0.00393 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.01299 seconds
Time After: 0.01332 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.01356 seconds
Time After: 0.01370 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.01439 seconds
Time After: 0.01636 seconds
Time Taken: 0.00197 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.01377 seconds
Time After: 0.02114 seconds
Time Taken: 0.00737 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.02542 seconds
Time After: 0.02572 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.02766 seconds
Time After: 0.02879 seconds
Time Taken: 0.00113 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.02482 seconds
Time After: 0.02901 seconds
Time Taken: 0.00419 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.04886 seconds
Time After: 0.04900 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.05841 seconds
Time After: 0.05965 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.062175989151001
Time Before: 0.06591 seconds
Time After: 0.06605 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.06793 seconds
Time After: 0.06945 seconds
Time Taken: 0.00152 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=50448'
Time Before: 0.08875 seconds
Time After: 0.08899 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.087369918823242 seconds with 9 queries, spending 0.0071523189544678 doing MySQL queries and 0.080217599868774 doing PHP things.
