Time Before: 0.02610 seconds
Time After: 0.03574 seconds
Time Taken: 0.00963 seconds
Time Before: 0.03582 seconds
Time After: 0.03638 seconds
Time Taken: 0.00056 seconds
Time Before: 0.03666 seconds
Time After: 0.03684 seconds
Time Before: 0.03761 seconds
Time After: 0.04008 seconds
Time Taken: 0.00247 seconds
Time Before: 0.03689 seconds
Time After: 0.04440 seconds
Time Taken: 0.00751 seconds
Time Before: 0.05314 seconds
Time After: 0.05345 seconds
Time Before: 0.05533 seconds
Time After: 0.05653 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05248 seconds
Time After: 0.05678 seconds
Time Taken: 0.00429 seconds
Memory After: 2,261.719 KB
Time Before: 0.09243 seconds
Time After: 0.09260 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.11348 seconds
Time After: 0.11474 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.11666202545166
Time Before: 0.12441 seconds
Time After: 0.12457 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12669 seconds
Time After: 0.12814 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=50529', badlocation = 1
Time Before: 0.14533 seconds
Time After: 0.14562 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.14437007904053 seconds with 9 queries, spending 0.0080556869506836 doing MySQL queries and 0.13631439208984 doing PHP things.
