Time Before: 0.00152 seconds
Time After: 0.00199 seconds
Time Before: 0.00206 seconds
Time After: 0.00324 seconds
Time Taken: 0.00118 seconds
Time Before: 0.00348 seconds
Time After: 0.00361 seconds
Time Before: 0.00426 seconds
Time After: 0.00683 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00366 seconds
Time After: 0.01020 seconds
Time Taken: 0.00654 seconds
Time Before: 0.01207 seconds
Time After: 0.01243 seconds
Time Before: 0.01513 seconds
Time After: 0.01633 seconds
Time Before: 0.01151 seconds
Time After: 0.01652 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02166 seconds
Time After: 0.02179 seconds
Time Before: 0.02358 seconds
Time After: 0.02479 seconds
Time Before: 0.02759 seconds
Time After: 0.02773 seconds
Time Before: 0.02971 seconds
Time After: 0.03115 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=50540', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.04613 seconds
Time After: 0.04649 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
