Time Before: 0.00675 seconds
Time After: 0.00934 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00943 seconds
Time After: 0.00986 seconds
Time Before: 0.01009 seconds
Time After: 0.01023 seconds
Time Before: 0.01108 seconds
Time After: 0.01350 seconds
Time Taken: 0.00242 seconds
Time Before: 0.01028 seconds
Time After: 0.01689 seconds
Time Taken: 0.00660 seconds
Time Before: 0.01979 seconds
Time After: 0.02015 seconds
Time Before: 0.02275 seconds
Time After: 0.02393 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01922 seconds
Time After: 0.02411 seconds
Time Taken: 0.00489 seconds
Time Before: 0.03663 seconds
Time After: 0.03677 seconds
Time Before: 0.04204 seconds
Time After: 0.04324 seconds
End call of global.php: 0.045331954956055
Time Before: 0.04849 seconds
Time After: 0.04867 seconds
Time Before: 0.05117 seconds
Time After: 0.05269 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=50566'
Time Before: 0.07095 seconds
Time After: 0.07123 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
Page generated in 0.069775819778442 seconds with 9 queries, spending 0.0078520774841309 doing MySQL queries and 0.061923742294312 doing PHP things.
