Time Before: 0.00148 seconds
Time After: 0.00214 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00220 seconds
Time After: 0.00263 seconds
Time Before: 0.00293 seconds
Time After: 0.00346 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00436 seconds
Time After: 0.00710 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00354 seconds
Time After: 0.01134 seconds
Time Taken: 0.00779 seconds
Time Before: 0.01330 seconds
Time After: 0.01349 seconds
Time Before: 0.01612 seconds
Time After: 0.01757 seconds
Time Before: 0.01264 seconds
Time After: 0.01780 seconds
Time Taken: 0.00516 seconds
Time Before: 0.02376 seconds
Time After: 0.02391 seconds
Time Before: 0.02625 seconds
Time After: 0.02779 seconds
Time Taken: 0.00154 seconds
Time Before: 0.03162 seconds
Time After: 0.03179 seconds
Time Before: 0.03498 seconds
Time After: 0.03652 seconds
UPDATE session SET lastactivity = 1788908631, location = '/forums/private.php?do=newpm&explain=1&u=5070', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04939 seconds
Time After: 0.04981 seconds
Memory Before: 4,911.445 KB
Memory After: 4,911.656 KB
