Time Before: 0.02536 seconds
Time After: 0.03873 seconds
Time Taken: 0.01338 seconds
Time Before: 0.03882 seconds
Time After: 0.03925 seconds
Time Before: 0.03945 seconds
Time After: 0.03958 seconds
Time Before: 0.04029 seconds
Time After: 0.04261 seconds
Time Taken: 0.00232 seconds
Time Before: 0.03964 seconds
Time After: 0.04714 seconds
Time Taken: 0.00750 seconds
Time Before: 0.06090 seconds
Time After: 0.06130 seconds
Time Before: 0.06396 seconds
Time After: 0.06521 seconds
Time Before: 0.06004 seconds
Time After: 0.06542 seconds
Time Taken: 0.00538 seconds
Time Before: 0.11775 seconds
Time After: 0.11790 seconds
Time Before: 0.14031 seconds
Time After: 0.14156 seconds
End call of global.php: 0.14391088485718
Time Before: 0.15160 seconds
Time After: 0.15175 seconds
Time Before: 0.15450 seconds
Time After: 0.15595 seconds
SET lastactivity = 1776538520, location = '/forums/private.php?do=newpm&explain=1&u=50772'
Time Before: 0.17774 seconds
Time After: 0.17823 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.17647480964661 seconds with 9 queries, spending 0.0080192089080811 doing MySQL queries and 0.16845560073853 doing PHP things.
