Time Before: 0.00709 seconds
Time After: 0.01012 seconds
Time Taken: 0.00303 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.01023 seconds
Time After: 0.01060 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.01080 seconds
Time After: 0.01098 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.01183 seconds
Time After: 0.01412 seconds
Time Taken: 0.00229 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.01105 seconds
Time After: 0.01760 seconds
Time Taken: 0.00654 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.02085 seconds
Time After: 0.02119 seconds
Time Before: 0.02383 seconds
Time After: 0.02500 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02026 seconds
Time After: 0.02521 seconds
Time Taken: 0.00495 seconds
Memory After: 2,261.820 KB
Time Before: 0.03958 seconds
Time After: 0.03975 seconds
Memory Before: 2,815.414 KB
Memory After: 2,815.930 KB
Time Before: 0.04645 seconds
Time After: 0.04769 seconds
Memory Before: 2,903.719 KB
Memory After: 2,904.313 KB
End call of global.php: 0.049913167953491
Time Before: 0.05378 seconds
Time After: 0.05393 seconds
Memory Before: 3,540.484 KB
Memory After: 3,540.914 KB
Time Before: 0.05637 seconds
Time After: 0.05782 seconds
Memory Before: 3,822.031 KB
Memory After: 3,823.703 KB
Memory Used: 1.672 KB
SET lastactivity = 1785348913, location = '/forums/private.php?do=newpm&explain=1&u=50780'
Time Before: 0.07518 seconds
Time After: 0.07551 seconds
Memory Before: 4,295.875 KB
Memory After: 4,296.102 KB
Page generated in 0.074141025543213 seconds with 9 queries, spending 0.0076801776885986 doing MySQL queries and 0.066460847854614 doing PHP things.
