Time Before: 0.01219 seconds
Time After: 0.01882 seconds
Time Taken: 0.00663 seconds
Time Before: 0.01894 seconds
Time After: 0.01932 seconds
Time Before: 0.01957 seconds
Time After: 0.02023 seconds
Time Taken: 0.00066 seconds
Time Before: 0.02128 seconds
Time After: 0.02518 seconds
Time Taken: 0.00390 seconds
Time Before: 0.02029 seconds
Time After: 0.02955 seconds
Time Taken: 0.00925 seconds
Time Before: 0.03466 seconds
Time After: 0.03504 seconds
Time Before: 0.03733 seconds
Time After: 0.03853 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03401 seconds
Time After: 0.03878 seconds
Time Taken: 0.00477 seconds
Memory After: 2,261.836 KB
Time Before: 0.06168 seconds
Time After: 0.06186 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.07422 seconds
Time After: 0.07546 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.078476905822754
Time Before: 0.08248 seconds
Time After: 0.08265 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.08601 seconds
Time After: 0.08746 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789103847, location = '/forums/private.php?do=newpm&explain=1&u=50826', badlocation = 1
Time Before: 0.10924 seconds
Time After: 0.10951 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.10780501365662 seconds with 9 queries, spending 0.0098099708557129 doing MySQL queries and 0.097995042800903 doing PHP things.
