Time Before: 0.00672 seconds
Time After: 0.00882 seconds
Time Taken: 0.00210 seconds
Time Before: 0.00891 seconds
Time After: 0.00933 seconds
Time Before: 0.00959 seconds
Time After: 0.00972 seconds
Time Before: 0.01057 seconds
Time After: 0.01349 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00979 seconds
Time After: 0.01895 seconds
Time Taken: 0.00916 seconds
Time Before: 0.02242 seconds
Time After: 0.02283 seconds
Time Before: 0.02472 seconds
Time After: 0.02648 seconds
Time Taken: 0.00176 seconds
Time Before: 0.02162 seconds
Time After: 0.02676 seconds
Time Taken: 0.00514 seconds
Time Before: 0.03394 seconds
Time After: 0.03409 seconds
Time Before: 0.03727 seconds
Time After: 0.03853 seconds
Time Before: 0.04340 seconds
Time After: 0.04357 seconds
Time Before: 0.04685 seconds
Time After: 0.04837 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1783166191, location = '/forums/private.php?do=newpm&explain=1&u=50832', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.06276 seconds
Time After: 0.06317 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
