Time Before: 0.02500 seconds
Time After: 0.03003 seconds
Time Taken: 0.00503 seconds
Time Before: 0.03016 seconds
Time After: 0.03084 seconds
Time Taken: 0.00068 seconds
Time Before: 0.03111 seconds
Time After: 0.03134 seconds
Time Before: 0.03226 seconds
Time After: 0.03499 seconds
Time Taken: 0.00273 seconds
Time Before: 0.03142 seconds
Time After: 0.04039 seconds
Time Taken: 0.00897 seconds
Time Before: 0.04759 seconds
Time After: 0.04781 seconds
Time Before: 0.05041 seconds
Time After: 0.05164 seconds
Time Before: 0.04690 seconds
Time After: 0.05188 seconds
Time Taken: 0.00498 seconds
Time Before: 0.08558 seconds
Time After: 0.08576 seconds
Time Before: 0.09883 seconds
Time After: 0.10011 seconds
End call of global.php: 0.10236597061157
Time Before: 0.11087 seconds
Time After: 0.11101 seconds
Time Before: 0.11367 seconds
Time After: 0.11512 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=50835'
Time Before: 0.13369 seconds
Time After: 0.13407 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.1325478553772 seconds with 9 queries, spending 0.0085330009460449 doing MySQL queries and 0.12401485443115 doing PHP things.
