Time Before: 0.02419 seconds
Time After: 0.03137 seconds
Time Taken: 0.00717 seconds
Time Before: 0.03145 seconds
Time After: 0.03194 seconds
Time Before: 0.03219 seconds
Time After: 0.03235 seconds
Time Before: 0.03323 seconds
Time After: 0.03571 seconds
Time Taken: 0.00248 seconds
Time Before: 0.03243 seconds
Time After: 0.03990 seconds
Time Taken: 0.00747 seconds
Time Before: 0.04726 seconds
Time After: 0.04775 seconds
Time Before: 0.05023 seconds
Time After: 0.05144 seconds
Time Before: 0.04653 seconds
Time After: 0.05162 seconds
Time Taken: 0.00509 seconds
Time Before: 0.08808 seconds
Time After: 0.08820 seconds
Time Before: 0.10105 seconds
Time After: 0.10238 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.10460686683655
Time Before: 0.11184 seconds
Time After: 0.11201 seconds
Time Before: 0.11457 seconds
Time After: 0.11598 seconds
SET lastactivity = 1776628331, location = '/forums/private.php?do=newpm&explain=1&u=50842'
Time Before: 0.13692 seconds
Time After: 0.13731 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.13579106330872 seconds with 9 queries, spending 0.0082452297210693 doing MySQL queries and 0.12754583358765 doing PHP things.
