Time Before: 0.00162 seconds
Time After: 0.00209 seconds
Time Before: 0.00219 seconds
Time After: 0.00274 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00300 seconds
Time After: 0.00315 seconds
Time Before: 0.00405 seconds
Time After: 0.00652 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00323 seconds
Time After: 0.01150 seconds
Time Taken: 0.00827 seconds
Time Before: 0.01402 seconds
Time After: 0.01444 seconds
Time Before: 0.01744 seconds
Time After: 0.01867 seconds
Time Before: 0.01322 seconds
Time After: 0.01893 seconds
Time Taken: 0.00571 seconds
Time Before: 0.02594 seconds
Time After: 0.02609 seconds
Time Before: 0.02847 seconds
Time After: 0.02977 seconds
End call of global.php: 0.032553911209106
Time Before: 0.03399 seconds
Time After: 0.03413 seconds
Time Before: 0.03701 seconds
Time After: 0.03843 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=50870', badlocation = 1
Time Before: 0.05233 seconds
Time After: 0.05260 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.05129599571228 seconds with 9 queries, spending 0.0080966949462891 doing MySQL queries and 0.043199300765991 doing PHP things.
