Time Before: 0.00209 seconds
Time After: 0.00265 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00275 seconds
Time After: 0.00315 seconds
Time Before: 0.00337 seconds
Time After: 0.00348 seconds
Time Before: 0.00427 seconds
Time After: 0.00747 seconds
Time Taken: 0.00320 seconds
Time Before: 0.00356 seconds
Time After: 0.01226 seconds
Time Taken: 0.00870 seconds
Time Before: 0.01421 seconds
Time After: 0.01454 seconds
Time Before: 0.01646 seconds
Time After: 0.01771 seconds
Time Before: 0.01356 seconds
Time After: 0.01797 seconds
Time Taken: 0.00441 seconds
Time Before: 0.02493 seconds
Time After: 0.02506 seconds
Time Before: 0.02733 seconds
Time After: 0.02854 seconds
End call of global.php: 0.031061172485352
Time Before: 0.03234 seconds
Time After: 0.03247 seconds
Time Before: 0.03529 seconds
Time After: 0.03669 seconds
Time Taken: 0.00139 seconds
SET lastactivity = 1777071054, location = '/forums/private.php?do=newpm&explain=1&u=50912', badlocation = 1
WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.05175 seconds
Time After: 0.05203 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.050808191299438 seconds with 9 queries, spending 0.0084629058837891 doing MySQL queries and 0.042345285415649 doing PHP things.
