Time Before: 0.00858 seconds
Time After: 0.01166 seconds
Time Taken: 0.00308 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.01174 seconds
Time After: 0.01217 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.01245 seconds
Time After: 0.01258 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.01353 seconds
Time After: 0.01578 seconds
Time Taken: 0.00225 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.01265 seconds
Time After: 0.02127 seconds
Time Taken: 0.00862 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.02591 seconds
Time After: 0.02634 seconds
Time Before: 0.02791 seconds
Time After: 0.02914 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02508 seconds
Time After: 0.02938 seconds
Time Taken: 0.00429 seconds
Memory After: 2,261.703 KB
Time Before: 0.05426 seconds
Time After: 0.05443 seconds
Memory Before: 2,815.273 KB
Memory After: 2,815.789 KB
Time Before: 0.06342 seconds
Time After: 0.06468 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.066895008087158
Time Before: 0.07166 seconds
Time After: 0.07181 seconds
Memory Before: 3,540.375 KB
Memory After: 3,540.805 KB
Time Before: 0.07434 seconds
Time After: 0.07579 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=50972'
Time Before: 0.09311 seconds
Time After: 0.09347 seconds
Memory Before: 4,295.484 KB
Memory After: 4,295.727 KB
Page generated in 0.092120885848999 seconds with 9 queries, spending 0.007868766784668 doing MySQL queries and 0.084252119064331 doing PHP things.
