Time Before: 0.00919 seconds
Time After: 0.01096 seconds
Time Taken: 0.00177 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01105 seconds
Time After: 0.01154 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.01189 seconds
Time After: 0.01205 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.01292 seconds
Time After: 0.01510 seconds
Time Taken: 0.00218 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.01212 seconds
Time After: 0.02000 seconds
Time Taken: 0.00788 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.02335 seconds
Time After: 0.02371 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.02649 seconds
Time After: 0.02767 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.02258 seconds
Time After: 0.02790 seconds
Time Taken: 0.00532 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.04230 seconds
Time After: 0.04276 seconds
Memory Before: 3,655.680 KB
Memory After: 3,656.195 KB
Time Before: 0.60866 seconds
Time After: 0.61063 seconds
Time Taken: 0.00197 seconds
Memory Before: 4,133.273 KB
Memory After: 4,133.867 KB
Time Before: 0.62039 seconds
Time After: 0.62082 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.62345 seconds
Time After: 0.62525 seconds
Time Taken: 0.00180 seconds
Memory Before: 5,481.203 KB
Memory After: 5,610.805 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=51006', badlocation = 1 WHERE sessionhash = '92ff6a36ca798bc15f3564bfe954b6e0'
Time Before: 0.63917 seconds
Time After: 0.63948 seconds
Memory Before: 5,998.508 KB
Memory After: 5,998.727 KB
