Time Before: 0.02917 seconds
Time After: 0.04479 seconds
Time Taken: 0.01562 seconds
Time Before: 0.04488 seconds
Time After: 0.04529 seconds
Time Before: 0.04561 seconds
Time After: 0.04577 seconds
Time Before: 0.04665 seconds
Time After: 0.04854 seconds
Time Taken: 0.00189 seconds
Time Before: 0.04587 seconds
Time After: 0.05313 seconds
Time Taken: 0.00726 seconds
Time Before: 0.07393 seconds
Time After: 0.07434 seconds
Time Before: 0.07775 seconds
Time After: 0.07895 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.07321 seconds
Time After: 0.07918 seconds
Time Taken: 0.00597 seconds
Memory After: 2,261.836 KB
Time Before: 0.11942 seconds
Time After: 0.11959 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.14287 seconds
Time After: 0.14414 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.15687 seconds
Time After: 0.15702 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.15971 seconds
Time After: 0.16117 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789051440, location = '/forums/private.php?do=newpm&explain=1&u=51089', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.18147 seconds
Time After: 0.18248 seconds
Time Taken: 0.00101 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
