Time Before: 0.00412 seconds
Time After: 0.00620 seconds
Time Taken: 0.00209 seconds
Time Before: 0.00627 seconds
Time After: 0.00675 seconds
Time Before: 0.00697 seconds
Time After: 0.00712 seconds
Time Before: 0.00809 seconds
Time After: 0.01024 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00719 seconds
Time After: 0.01430 seconds
Time Taken: 0.00710 seconds
Time Before: 0.01916 seconds
Time After: 0.01957 seconds
Time Before: 0.02205 seconds
Time After: 0.02324 seconds
Time Before: 0.01845 seconds
Time After: 0.02344 seconds
Time Taken: 0.00498 seconds
Time Before: 0.03362 seconds
Time After: 0.03376 seconds
Time Before: 0.04097 seconds
Time After: 0.04221 seconds
Time Before: 0.04822 seconds
Time After: 0.04842 seconds
Time Before: 0.05074 seconds
Time After: 0.05224 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=51262' WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.06748 seconds
Time After: 0.06789 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
