Time Before: 0.00139 seconds
Time After: 0.00197 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00204 seconds
Time After: 0.00251 seconds
Time Before: 0.00278 seconds
Time After: 0.00292 seconds
Time Before: 0.00386 seconds
Time After: 0.00650 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00300 seconds
Time After: 0.00993 seconds
Time Taken: 0.00693 seconds
Time Before: 0.01187 seconds
Time After: 0.01228 seconds
Time Before: 0.01388 seconds
Time After: 0.01539 seconds
Time Taken: 0.00151 seconds
Time Before: 0.01129 seconds
Time After: 0.01572 seconds
Time Taken: 0.00443 seconds
Time Before: 0.02299 seconds
Time After: 0.02315 seconds
Time Before: 0.02589 seconds
Time After: 0.02745 seconds
Time Taken: 0.00156 seconds
Time Before: 0.03192 seconds
Time After: 0.03209 seconds
Time Before: 0.03518 seconds
Time After: 0.03669 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=51284' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04973 seconds
Time After: 0.05020 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
