Time Before: 0.00331 seconds
Time After: 0.00408 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00419 seconds
Time After: 0.00456 seconds
Time Before: 0.00479 seconds
Time After: 0.00491 seconds
Time Before: 0.00581 seconds
Time After: 0.00780 seconds
Time Taken: 0.00199 seconds
Time Before: 0.00499 seconds
Time After: 0.01243 seconds
Time Taken: 0.00744 seconds
Time Before: 0.01452 seconds
Time After: 0.01501 seconds
Time Before: 0.01802 seconds
Time After: 0.01925 seconds
Time Before: 0.01374 seconds
Time After: 0.01949 seconds
Time Taken: 0.00575 seconds
Time Before: 0.02596 seconds
Time After: 0.02609 seconds
Time Before: 0.02802 seconds
Time After: 0.02925 seconds
End call of global.php: 0.031000852584839
Time Before: 0.03221 seconds
Time After: 0.03235 seconds
Time Before: 0.03442 seconds
Time After: 0.03589 seconds
SET lastactivity = 1789022781, location = '/forums/private.php?do=newpm&explain=1&u=51285'
Time Before: 0.04871 seconds
Time After: 0.04906 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.047792911529541 seconds with 9 queries, spending 0.0075232982635498 doing MySQL queries and 0.040269613265991 doing PHP things.
