Time Before: 0.00145 seconds
Time After: 0.00205 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00215 seconds
Time After: 0.00268 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00290 seconds
Time After: 0.00303 seconds
Time Before: 0.00373 seconds
Time After: 0.00620 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00308 seconds
Time After: 0.00958 seconds
Time Taken: 0.00650 seconds
Time Before: 0.01140 seconds
Time After: 0.01177 seconds
Time Before: 0.01443 seconds
Time After: 0.01571 seconds
Time Before: 0.01082 seconds
Time After: 0.01589 seconds
Time Taken: 0.00507 seconds
Time Before: 0.02107 seconds
Time After: 0.02131 seconds
Time Before: 0.02327 seconds
Time After: 0.02455 seconds
End call of global.php: 0.026242017745972
Time Before: 0.02737 seconds
Time After: 0.02764 seconds
Time Before: 0.02972 seconds
Time After: 0.03123 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1789140297, location = '/forums/private.php?do=newpm&explain=1&u=51324'
Time Before: 0.04373 seconds
Time After: 0.04401 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.042800903320312 seconds with 9 queries, spending 0.0083670616149902 doing MySQL queries and 0.034433841705322 doing PHP things.
