Time Before: 0.00137 seconds
Time After: 0.00190 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00197 seconds
Time After: 0.00239 seconds
Time Before: 0.00264 seconds
Time After: 0.00278 seconds
Time Before: 0.00353 seconds
Time After: 0.00775 seconds
Time Taken: 0.00422 seconds
Time Before: 0.00286 seconds
Time After: 0.01112 seconds
Time Taken: 0.00827 seconds
Time Before: 0.01287 seconds
Time After: 0.01325 seconds
Time Before: 0.01566 seconds
Time After: 0.01688 seconds
Time Before: 0.01232 seconds
Time After: 0.01708 seconds
Time Taken: 0.00476 seconds
Time Before: 0.02197 seconds
Time After: 0.02210 seconds
Time Before: 0.02393 seconds
Time After: 0.02524 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.027238130569458
Time Before: 0.02850 seconds
Time After: 0.02865 seconds
Time Before: 0.03082 seconds
Time After: 0.03223 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=51478'
Time Before: 0.04938 seconds
Time After: 0.04970 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.048442125320435 seconds with 9 queries, spending 0.00970458984375 doing MySQL queries and 0.038737535476685 doing PHP things.
