Time Before: 0.00192 seconds
Time After: 0.00250 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00258 seconds
Time After: 0.00300 seconds
Time Before: 0.00322 seconds
Time After: 0.00333 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00397 seconds
Time After: 0.00624 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00337 seconds
Time After: 0.00962 seconds
Time Taken: 0.00625 seconds
Time Before: 0.01148 seconds
Time After: 0.01190 seconds
Time Before: 0.01438 seconds
Time After: 0.01559 seconds
Time Before: 0.01083 seconds
Time After: 0.01576 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02176 seconds
Time After: 0.02193 seconds
Time Before: 0.02384 seconds
Time After: 0.02509 seconds
Time Before: 0.02797 seconds
Time After: 0.02814 seconds
Time Before: 0.03011 seconds
Time After: 0.03155 seconds
UPDATE session SET lastactivity = 1788965705, location = '/forums/private.php?do=newpm&explain=1&u=51597' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04385 seconds
Time After: 0.04422 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
