Time Before: 0.00198 seconds
Time After: 0.00268 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00278 seconds
Time After: 0.00340 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00370 seconds
Time After: 0.00384 seconds
Time Before: 0.00474 seconds
Time After: 0.00727 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00392 seconds
Time After: 0.01226 seconds
Time Taken: 0.00834 seconds
Time Before: 0.01463 seconds
Time After: 0.01499 seconds
Time Before: 0.01633 seconds
Time After: 0.01751 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01398 seconds
Time After: 0.01776 seconds
Time Taken: 0.00378 seconds
Time Before: 0.02300 seconds
Time After: 0.02319 seconds
Time Before: 0.02533 seconds
Time After: 0.02678 seconds
End call of global.php: 0.029810905456543
Time Before: 0.03137 seconds
Time After: 0.03163 seconds
Time Before: 0.03374 seconds
Time After: 0.03517 seconds
SET lastactivity = 1776722610, location = '/forums/private.php?do=newpm&explain=1&u=51730'
Time Before: 0.04846 seconds
Time After: 0.04872 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.047513961791992 seconds with 9 queries, spending 0.0084199905395508 doing MySQL queries and 0.039093971252441 doing PHP things.
