Time Before: 0.00147 seconds
Time After: 0.00208 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00216 seconds
Time After: 0.00294 seconds
Time Taken: 0.00078 seconds
Time Before: 0.00332 seconds
Time After: 0.00352 seconds
Time Before: 0.00425 seconds
Time After: 0.00719 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00359 seconds
Time After: 0.01059 seconds
Time Taken: 0.00700 seconds
Time Before: 0.01248 seconds
Time After: 0.01297 seconds
Time Before: 0.01447 seconds
Time After: 0.01605 seconds
Time Taken: 0.00158 seconds
Time Before: 0.01187 seconds
Time After: 0.01623 seconds
Time Taken: 0.00436 seconds
Time Before: 0.02132 seconds
Time After: 0.02149 seconds
Time Before: 0.02341 seconds
Time After: 0.02476 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.026411056518555
Time Before: 0.02775 seconds
Time After: 0.02795 seconds
Time Before: 0.03008 seconds
Time After: 0.03156 seconds
SET lastactivity = 1784867541, location = '/forums/private.php?do=newpm&explain=1&u=51759', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04420 seconds
Time After: 0.04446 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.043291091918945 seconds with 9 queries, spending 0.0094549655914307 doing MySQL queries and 0.033836126327515 doing PHP things.
