Time Before: 0.00137 seconds
Time After: 0.00189 seconds
Time Before: 0.00199 seconds
Time After: 0.00250 seconds
Time Before: 0.00278 seconds
Time After: 0.00296 seconds
Time Before: 0.00383 seconds
Time After: 0.00666 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00303 seconds
Time After: 0.01100 seconds
Time Taken: 0.00797 seconds
Time Before: 0.01278 seconds
Time After: 0.01316 seconds
Time Before: 0.01579 seconds
Time After: 0.01706 seconds
Time Before: 0.01219 seconds
Time After: 0.01731 seconds
Time Taken: 0.00512 seconds
Time Before: 0.02321 seconds
Time After: 0.02338 seconds
Time Before: 0.02551 seconds
Time After: 0.02678 seconds
Time Before: 0.03093 seconds
Time After: 0.03109 seconds
Time Before: 0.03397 seconds
Time After: 0.03543 seconds
UPDATE session SET lastactivity = 1783081441, location = '/forums/private.php?do=newpm&explain=1&u=51769' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04979 seconds
Time After: 0.05012 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
