Time Before: 0.02175 seconds
Time After: 0.03002 seconds
Time Taken: 0.00827 seconds
Time Before: 0.03010 seconds
Time After: 0.03056 seconds
Time Before: 0.03079 seconds
Time After: 0.03093 seconds
Time Before: 0.03186 seconds
Time After: 0.03415 seconds
Time Taken: 0.00230 seconds
Time Before: 0.03101 seconds
Time After: 0.03824 seconds
Time Taken: 0.00723 seconds
Time Before: 0.04845 seconds
Time After: 0.04890 seconds
Time Before: 0.05232 seconds
Time After: 0.05402 seconds
Time Taken: 0.00170 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04747 seconds
Time After: 0.05428 seconds
Time Taken: 0.00681 seconds
Memory After: 2,261.836 KB
Time Before: 0.09506 seconds
Time After: 0.09520 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.11670 seconds
Time After: 0.11813 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.12127995491028
Time Before: 0.13030 seconds
Time After: 0.13046 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.13329 seconds
Time After: 0.13508 seconds
Time Taken: 0.00179 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788946106, location = '/forums/private.php?do=newpm&explain=1&u=5179'
Time Before: 0.15337 seconds
Time After: 0.15374 seconds
Memory Before: 4,287.586 KB
Memory After: 4,287.805 KB
Page generated in 0.15232276916504 seconds with 9 queries, spending 0.0089340209960938 doing MySQL queries and 0.14338874816895 doing PHP things.
