Time Before: 0.02349 seconds
Time After: 0.02773 seconds
Time Taken: 0.00424 seconds
Time Before: 0.02780 seconds
Time After: 0.02826 seconds
Time Before: 0.02845 seconds
Time After: 0.02859 seconds
Time Before: 0.02943 seconds
Time After: 0.03164 seconds
Time Taken: 0.00221 seconds
Time Before: 0.02864 seconds
Time After: 0.03551 seconds
Time Taken: 0.00687 seconds
Time Before: 0.04137 seconds
Time After: 0.04181 seconds
Time Before: 0.04449 seconds
Time After: 0.04575 seconds
Time Before: 0.04061 seconds
Time After: 0.04603 seconds
Time Taken: 0.00542 seconds
Time Before: 0.07510 seconds
Time After: 0.07528 seconds
Time Before: 0.09727 seconds
Time After: 0.09854 seconds
End call of global.php: 0.10062789916992
Time Before: 0.11033 seconds
Time After: 0.11047 seconds
Time Before: 0.11315 seconds
Time After: 0.11466 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1782902686, location = '/forums/private.php?do=newpm&explain=1&u=51949'
Time Before: 0.13285 seconds
Time After: 0.13323 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.13176107406616 seconds with 9 queries, spending 0.007990837097168 doing MySQL queries and 0.12377023696899 doing PHP things.
